I wanted to start on a seal chart to have here for everyone to use. I could use some help if any of you have the time.
I have this from what I researched and ordered last week. The first number is the CR/SKF #, then the WH #, then what it fits. The list isn't in order and should probably have the WH # first and ordered by that, but Sandra can fix it.
CR 6105..........100442..........5/8 .625 Main Input Shaft
CR 7410..........100441..........3/4 .750 Brake Shaft
CR 9815..........100863..........1" 1.00 Axle Shaft
CR 11050........100443..........1 1/8" 1.125 Axle Shaft
CR 12330........103118..........Tiller Shaft
CR 11124........6449..............520H Rear Axle Shaft
If any of you have seal numbers you know work and where they fit please make a post in here and I'll add it to the list. When we get enough of them Sandra can put them in a document.
