New Parts Topic
27 Aug 2018 11:15 - 27 Aug 2018 11:17 #14830
Point cover screws and 7879 bushing replacements are in the store. The bushings are awesome and half the price of the Toro. They are here -
Wheel Horse 7879 Bushing
The points cover screws may be the only ones available anywhere with the internal lock washer on them. They are here - Kohler Points Cover Screws
Will try to do more later, time to get to work in the shop now.
Last edit: 27 Aug 2018 11:17 by Geno.
30 Aug 2018 18:15 #14836
Did the Kohler Magnum double clips for the throttle and choke, and the original fuel shut offs with the screen today. I think I may make up the plug wires next.
30 Aug 2018 18:18 #14837
Also on the to do list I haven't mentioned is new throttle and choke cable replacements for the lever style controls. Been doing this here for awhile. I can make the cable where someone can just install it to and reuse the factory lever. It's a lot cheaper to do it that way if the lever is still good.
31 Aug 2018 06:10 #14840
Replied by GT 14 on topic New Parts Topic
Geno wrote: Also on the to do list I haven't mentioned is new throttle and choke cable replacements for the lever style controls. Been doing this here for awhile. I can make the cable where someone can just install it to and reuse the factory lever. It's a lot cheaper to do it that way if the lever is still good.
31 Aug 2018 18:24 - 31 Aug 2018 18:26 #14841
Spent too much time in the shop working and with some peeps from IL today but did get 1 new part in the store. It's a replacement for the 115230 micro switch used on the 520 and others for the neutral switch. I'll be putting the 111332 PTO switches in there soon also.
It is here - Neutral Switch
Last edit: 31 Aug 2018 18:26 by Geno.
03 Sep 2018 07:27 #14844
Micro switches cause Maxi headaches
07 Sep 2018 19:33 #14851
Working on a few new unexpected projects, but necessity is the mother...
1st is the WH #101710 hood attachment rod. It works on everything I've checked so far from 1971 or so up. They run around $38 most everywhere minus a few crazies so I expect these to be around $10 and will even have clips with it lol.
2nd is the WH #102672mid attach rod. The rod is no longer available so I'm not sure if I should do the rod separately or do it as an assembly with the cam stop, spring and cap. It takes awhile to make the cam stop. What do you guys think?
08 Sep 2018 12:39 #14854
It may be a little overkill but the next batch of slot hitch tongues are milled on the ends, no bandsaw marks and perfectly square lol.
19 Sep 2018 18:15 #14864
Did the first batch of hood rods today, I think I have a system down but they are pretty labor intensive. The 1st pic is a stop I made to set the rod in the lathe, 2nd + 3rd pics are the way I'm getting the e-ring depth to .035 where it belongs. Not bad for the 1st run, at least they all match lol.
Time to create page: 0.344 seconds
