Leak at the brake
01 May 2016 07:23 #11318 by Trouty56
Replied by Trouty56 on topic Leak at the brake/wheel
Bearing may have been shot....
01 May 2016 07:38 #11319 by nappypappy
Replied by nappypappy on topic Leak at the brake/wheel
Trouty56 wrote: Bearing may have been shot....
..........guess I will have to take it apart and see what needs to be replaced...........:smile2 :wrain
01 May 2016 08:08 #11322 by Geno
Replied by Geno on topic Leak at the brake/wheel
The seal may have been not right when new or something happened putting it on that's just now showing up. Was there any rust where the seal sits? You can also jack it up and grab the wheel and see if it has play in it up and down or forward and back.
01 May 2016 08:33 #11323 by nappypappy
Geno wrote: The seal may have been not right when new or something happened putting it on that's just now showing up. Was there any rust where the seal sits? You can also jack it up and grab the wheel and see if it has play in it up and down or forward and back.
I didn't see any rust to speak of and old seal came out with no problem........new seal went in fine.....at least the leak at the axel stopped....will check for play...may just get another seal and try that after I get my jeep back on the road.....ordered parts for the 4.7 engine off ebay last night and should be here in a week....here in town parts were over 500 bucks but ebay less than 200 buckaroos....now I have to finish taking engine apart.....:cof3 :smile2
22 May 2016 03:19 - 22 May 2016 03:20 #11489 by nappypappy
well it leaks the worse at the brake...I was thinking could I have put the axel seal on the brake and the brake seal on the axel..........?
any ideas on that?
:smile2
Last edit: 22 May 2016 03:20 by nappypappy.
22 May 2016 07:46 #11490 by Geno
You would never get the brake seal on the axle lol. What were the seal numbers you used?
22 May 2016 08:08 #11491 by nappypappy
Geno wrote: You would never get the brake seal on the axle lol. What were the seal numbers you used?
Seal numbers...11050.....7410....I guess one was bigger than the other and the way things have been going here lately if they could have been put on wrong I am the man that can do it..:smile2
22 May 2016 09:59 #11492 by Geno
It's got the right seals in it.
23 May 2016 00:49 #11497 by nappypappy
Geno wrote: It's got the right seals in it.
ok ............:smile2
Time to create page: 0.286 seconds
