18 Automatic Tool Box
- 23 AUTOMATIC LSE
I may try taking pics of the plated parts I was able to bring home, and upload some.
- 23 AUTOMATIC LSE
P.S. I have prepped the hydro pump to motor manifold for clear coating to prevent tarnish or corrosion of the decorative polished copper plating.
23 AUTOMATIC LSE wrote: honestly do not think it should be considered a poor job, I had to sand the areas in front of the hinge halves, and this is where the finish was imperfect. Perhaps they can leave the cover in the copper or the nickel longer to achieve a thicker layer and subsequently alleviate any bleed through.
BIG LIKE!!!!
- 23 AUTOMATIC LSE
on the hinge areas.
On a side note the worker at the chrome shop said the lid and the 2 hinge halves was the only parts I had not yet picked up. This was not correct as I still did not receive the remainder of the parts from the first time I picked up parts. They said,"You received those when you picked up the first batch of parts.". I know that I didn't, so consequently I am now missing 2 hydro valve control levers, 2 {3} cups that bolt under the valves, 2 clevis pins that allow the levers to pivot, 2 {3} "S" hooks, 2 buckles with the wire balls. and a left threaded P.T.O. engagement rod nut. All of which I paid them to chrome, which is now at $40.00 minimum per part. They also sent the 2 "S" tubes back with the boss fitting nuts stuck to the curve portion of the tubes, after unsticking them there was bare copper plated areas that did not get chrome plated. I am going to have to see if they have found the lost parts when the reworked parts are finished. Not sure what to do if they try to say they don't have them.
- 23 AUTOMATIC LSE
I am going to check on some sort of material to form a seal around the perimeter of the box top. Then the only thing left will be assembly, after welding the box hinge half spacers, and the buckle supports. I do need to tweek the lid hinge halves as I failed to precompensate for the chrome plating taking up the gaps, so I am intending to remedy this by grinding a bit off of each. No pics yet but maybe forthcoming after a bit more progress.
What you are going through with the damaged, dirty, and not done correctly parts seems to be the norm these days, it's a real shame. That's the reason we do so much in house, to avoid the thought of wanting to kill people lol.
