Electric Fuel Pump
08 Jan 2016 19:09 - 08 Jan 2016 23:00 #9880
Electric Fuel Pump was created by Trouty56
The D series has a vacuum pump that sometimes takes a while to get fuel to the engine after the tractor sits a while.. Always wanted to try an electric one....got one for a little over 15 bucks off ebay. They are bigger than I thought....kinda hard to find a good spot for them. Still have to wire it and add a new filter after the tank/before the pump. I did install a filter before the carb....a small one.
www.ebay.com/itm/141682055890
Last edit: 08 Jan 2016 23:00 by Trouty56.
08 Jan 2016 19:47 #9882
Replied by Geno on topic Electric Fuel Pump
Really nice job Bob, looks like the prefect spot too.
Does that tractor have an oil pressure switch or a place to put one?
08 Jan 2016 22:58 #9883
Replied by Trouty56 on topic Electric Fuel Pump
It does not have an oil pressure gauge. However one could be added....
09 Jan 2016 08:01 #9884
I don't know much about the D's. Does that engine have a pressurized oil system?
09 Jan 2016 08:15 #9886
Replied by GT 14 on topic Electric Fuel Pump
Great job Bob, now that you have lots of fuel you can add a blower.
- Kurt-NEPA
09 Jan 2016 11:18 #9890
Replied by Kurt-NEPA on topic Electric Fuel Pump
Nice job Bob, I'm thinking of doing the same thing on my 520H's. The only thing stopping me is finding a good place to mount the pump.
Keep us posted on how this works out.
Kurt
Kurt
09 Jan 2016 17:20 #9891
Yes there is an oil pump.....some K482s have an oil filter....most of the 532's do....
Geno wrote: I don't know much about the D's. Does that engine have a pressurized oil system?
09 Jan 2016 18:08 #9892
If you have the pressurized system you can put an oil switch (not sender) in the engine that would shut off the electric pump after it starts. Something single terminal that can break the ground, or dual terminal to pass one of the pump wires through. Unless you want it to fun all the time the key is on.
09 Jan 2016 19:27 #9894
I'm taking the vacuum pump off....I think it is weak....so I need the electric one to run all the time.... Good idea though. Something like a primer.....right?
