Throttle shaft bushing fix
03 Jul 2015 04:51 - 03 Jul 2015 05:34 #6463 by Trouty56
Throttle shaft bushing fix was created by Trouty56
Be pulling a few carbs for rebuilds this year and if the throttle shaft is loose am going to try this.....
Info from the video...."THE THRUST BEARING IS 1/4 X 7/16 X 1/16 THICK BRONZE AND THE SCREWS ARE 3-48 X 1/4 BRASS,"
Guess he used a drill press for convenience to set the bronze thrust bearing.....quick and easy.....little loctite....
Tried to put some ebay link in.....no go!!!
Last edit: 03 Jul 2015 05:34 by Trouty56.
The following user(s) said Thank You: GT 14, M Bailey
03 Jul 2015 05:32 #6464 by GT 14
Replied by GT 14 on topic Throttle shaft bushing fix
Good info Bob
03 Jul 2015 08:31 #6471 by Geno
Replied by Geno on topic Throttle shaft bushing fix
I think Major has done this on a carb, someone around here has. :)
03 Jul 2015 09:12 - 03 Jul 2015 09:45 #6475 by M Bailey
Replied by M Bailey on topic Throttle shaft bushing fix
Geno wrote: I think Major has done this on a carb, someone around here has. :)
Great tip Bob and it really works well. Done a couple of them using 2 Hillman 58087-A 1/4 x 7/16 x 1/16 bronze thrust bearings stacked in the recess. A single would probably work okay but @ $.80 ea from Ace Hardware doubling them up seemed like a good idea.
Last edit: 03 Jul 2015 09:45 by M Bailey.
