A few more new parts
13 Oct 2016 12:23 #12516
A few more new parts was created by Geno
We're going to try to get a lot of new parts in the store soon, there's quite a few new things here and ready to go.
The latest that have come in in the past week is the fuel shut offs, fuel shut off bushings, hole plugs for the light + electric clutch switch on the plastic dash tractors, the deck lever release spring, and the thin clips for the tractor panels. We've been working on getting these parts for about a month and they are all finally here.
The biggest challenge on all of our parts is finding Made in USA, which all of the above also are.
14 Oct 2016 17:44 #12527
Replied by Geno on topic A few more new parts
The Fuel Category is now in the store and started. These were some of the parts that were hard to find Made in USA but these are!
There's still more to put in there but you can check it out here - WHS Store New Fuel Section
15 Oct 2016 10:58 #12530
The panel clips are in the store. We spent a lot of time finding the correct thin and flat nut that will not space up or bend the panels when mounting, they are just right and are here -
Panel Clips
We also have the elusive lift lever return springs in the store also here - Lift Lever Spring
28 Oct 2016 16:05 #12597
Just got some bearings in today. We've been working on the bearings for a long time that go in the older mule drive setup, Wheel Horse part #4567. They are finally here. They are made in China by a US company that runs the factory in China, that's why we even considered them, other than the fact that no one else makes one that's not an astronomical price lol.
The other thing we've been working on is a Made in USA Thrust bearing, the thrust washers we already have. The bearing was a WH# 1534, and the "Bearing Race Thrust" as WH called it was a WH#1535 These are for the gear drive decks and go at the top. They can also be used for the steering spindle modification and lots of other things that are on a 3/4" rod.
Time to create page: 0.085 seconds
