New Parts Topic
11 Jan 2020 08:05 #15709
The old Cole Boston 8394 split keys are here and in the store. They are a Wheel Horse # 3668.
They are here - Cole 8394
17 Jan 2020 10:08 - 17 Jan 2020 10:10 #15715
The Wheel Horse 2197 Lift Height Assy is in the Store.
I had to make one for Rob Smith (thanks Rob) so I made 2 prototypes that came out perfect. One is already sold to Rob and there is one more until more rod material gets here next week then I will get more of them in the store.
It is here - 2197 Lift Height Assy
Last edit: 17 Jan 2020 10:10 by Geno.
17 Jan 2020 11:33 #15716
Kohler 235118-S Breather Filters are in the store. They are also priced lower than dealer cost for 1 and it gets better with quantity.
They are here - Kohler 235118-S Breather Filter
25 Jan 2020 12:54 #15727
Just took a minute to get the 953, 1054, 1054A, GT-14, rear axle shaft keys in the store.
They are here - 937046 Woodruff Key
06 Feb 2020 12:40 #15749
Working on a lot of different projects now as some of you know but progress is being made. The J bolt only along with more of the kits will be in the store shortly, finished them up yesterday minus a little cleanup. The 953 / 1054 belt guard spacer kits are in progress and the chrome dust caps are here for them as well. There is also a lot more storage type stuff on the way to organize about 15-20K more nuts, bolts, keys, and other WH small parts that are either already here or on the way.
There are also a few other things in the works along with some new things in the pics below.
Some big ones will be done soon and are in the VIP Section.
10 Feb 2020 08:58 - 10 Feb 2020 09:12 #15754
Last edit: 10 Feb 2020 09:12 by Geno.
12 Feb 2020 09:18 #15756
The 3372 Chrome dust caps that fit the 953, 1054, 1054A, and GT-14 are now in the store. They are fancy lol.
They are here - Chrome Dust Caps
18 Feb 2020 08:31 - 18 Feb 2020 08:35 #15773
Working on a new stud/lug nut kit for the tractors, they are super cool. They will come with grade 9 yellow zinc bolts + lock washers, and a choice of chrome or black anodized open end nuts, or chrome closed end nuts. All of the lug nuts also have the bulge end with a collar to prevent the socket from hitting the wheel and damaging the paint.
It took a little time to get the perfect bolt length that ended up almost flush with the end of the lug nut kits. This was done not only for looks but to keep the threads from being exposed to any elements. They are a part of the nut + bolt kits we'll be putting on every tractor we restore from now on and will be in the store soon.
Last edit: 18 Feb 2020 08:35 by Geno.
11 Sep 2020 15:44 #16374
Since the restores are caught up and the shop is closed getting it's makeover for a bit longer the store is going back on the priority list.
There are a lot of new things you guys have seen in the restores over the past 5-6 months that will being to get pics taken of and put in the store soon. I would like to get a few tricycle kits built as well.
The input shaft and brake shaft seals (#1234) for the 3 piece transmissions will be here next Monday, and as of a few days ago I've been working with NOK Singapore directly about the seals they made for the axle shafts (#1257). I have some of them NOS and got all of the info I needed to contact them and see if they still make them or they can be put back into production at a reasonable cost.
I will update in here as things happen.
17 Sep 2020 13:49 #16387
Put a few more new things in this morning. Going over to dad's to mow for a bit then will make separate posts on these, then do some more.
This mornings additions are 518211 bumpers, 106557, 108547, 104737 reflectors (same reflector different numbers), and chrome coil brackets.
