10 Mar 2017 07:04 #13486
That is a bullet proof front end!!
- 23 AUTOMATIC LSE
13 Mar 2017 00:05 - 13 Mar 2017 00:16 #13504
by 23 AUTOMATIC LSE
Thanks Geno and GT, "Bullet proof front end" for sure. I hope no one tries to shoot it, LOL. Now it's time to move onto the hopefully bullet proof back end, for just a bit of an update.
82.) Right-hand Transaxle Case
83.) R.H. Front Needle Bearing {1532} Installed, outside, inside
84.) R.H. rear Needle Bearing {1532} Installed, outside, inside
85.) Oil Filter Fitting, Installed
86.) Dowel Pin, Installed
87. - 88.) Ditto 82 - 83 for Left-hand
89.) Ditto 84 but uses {8049}
90.) Ditto 86 for Left-hand
Last edit: 13 Mar 2017 00:16 by 23 AUTOMATIC LSE.
13 Mar 2017 07:37 #13505
Wow, didn't know you were rebuilding the rear as well.
13 Mar 2017 07:43 #13506
:bow1 :surprised
- 23 AUTOMATIC LSE
15 Mar 2017 13:00 #13520
by 23 AUTOMATIC LSE
Yes, the only way to know what's in them is to open them up, besides I am converting to the larger bolts bull gear, end caps, and locknuts, not to mention the longer axles for duals. Does anyone know what the purpose of the allen set screw is, that is near the needle bearing in the lower part of the first pic, and just right of the right needle bearing in the second pic?
15 Mar 2017 19:23 #13524
Does anything sit there inside when it's assembled? If not it's probably just a plugged extra hole.
- 23 AUTOMATIC LSE
15 Mar 2017 21:17 #13527
by 23 AUTOMATIC LSE
This area gets covered by a gasket, and the gasket gets covered by the motor.
- 23 AUTOMATIC LSE
22 Mar 2017 20:01 - 22 Mar 2017 20:04 #13556
by 23 AUTOMATIC LSE
Parking Brake Pawl
91.) Parking pawl
92.) Parking shaft
93.) Spirol pin
94.) Installed
95.) Seal
96.) Inserted in case
97.) Shaft inserted in case
98.) Brake lever assembly
99.) Spirol pin
100.) Inserted in lever
101.) Installed on shaft
91.) Parking pawl
92.) Parking shaft
93.) Spirol pin
94.) Installed
95.) Seal
99.) Spirol pin
Last edit: 22 Mar 2017 20:04 by 23 AUTOMATIC LSE.
22 Mar 2017 20:18 #13557
:smile2
22 Mar 2017 22:41 #13562
Definitely better than factory.
Time to create page: 0.180 seconds
